It is currently Sat Jul 26, 2025 6:54 pm
PostPosted: Fri Jun 24, 2005 7:41 am
Did I read somewhere on the forum a while back about a cheaper hardware store solution to the tapered reamer from LMI or Stew-Mac? I have a few traditional endpins to install and don't want to spring for an expensive tool that I don't plan to use much!
Larry
PostPosted: Fri Jun 24, 2005 8:13 am
Yep. Most hardware stores have tapered reamers for use on small dia. pipe and such. They are 5 deg snd work just fine for 5 deg pins and cost about half.
PostPosted: Fri Jun 24, 2005 8:29 am
Hi Larry,
You can find it at ACE HARDWARE....$17.95
Works great!
WalterK
PostPosted: Fri Jun 24, 2005 8:54 am
I thought I saw them at Grizzly too!
PostPosted: Fri Jun 24, 2005 10:39 am
stewmacs 3 degree reamer works perfect for the Gurian pins --
PostPosted: Fri Jun 24, 2005 1:26 pm
Thanks Walter! I've given LMI and SM enough of my money for a little while...ACE is the place this time.
